Problems with CGI Webspace?
- Everything else
- Problems with CGI Webspace?
14-10-2024 8:57 AM
Is anyone else having problems with their CGI webspace?
I find that some pages (apparently at random) don't appear at certain times - there's no error in the browser, the page just doesn't appear. If I try to connect via my Cloudflare-secured domain name (advanced-ict.info) then I get a message to say that the connection failed, but the same page also won't be available directly via ccgi.virnuls.plus.com.
The strange thing is that if I return a few minutes later the page might work and another one might fail. This issue affects static pages, so it doesn't appear to be an issue with MySQL or anything.
Any ideas?
Message 1 of 1
(569 Views)
- Everything else
