Problem with initial web page
- Everything else
- Problem with initial web page
02-02-2008 10:32 PM
I've created a web page in httpdocs using nvu and it uploaded it and a video OK using Firefox fireFTP.
But, when I try to log onto it [www.magnetman.plus.com] the page appears briefly and then the standard plusnet page comes up and says I haven't uploaded a page yet
any ideas much appreciated.
Re: Problem with initial web page
02-02-2008 10:35 PM
If you don't want to replace it then rename it index.old.
Customer and Forum Moderator. Windows 10 Firefox 102.0 (64-bit (64-bit)
02-02-2008 11:01 PM
<meta http-equiv="refresh" content="1;url=http://webspace.plus.net/webspace_plusnet.html">
from your file and upload it again and it should work
02-02-2008 11:13 PM
Is this another case of someone editing the original index rather than replacing it.
We had an identical case towards the end of last year.
In that instance I ripped the page and advised them of the offending line.
Other than that I can't see why anyone would create a web page with that redirect in the head.
02-02-2008 11:35 PM
02-02-2008 11:37 PM
02-02-2008 11:58 PM
Thanx again
03-02-2008 10:59 PM
Most web editors will put the code in for you or copy from another site if your using a text editor
I have my videos in flash format at
http://www.crewetown.co.uk/sk8/vids.htm
The best of it is that it reduced the size from 40 megs to 10 megs as well this is the format used by Utube etc the best one is from
http://www.sothink.com/product/flashvideoencoder/
you may be able to use the trial if you are only doing an odd one there is lots of converts out there some free
- Everything else
