Problem with form submit - was working before
ratbag
I have a problem with form submission. I've made a minimal example to see if anyone can see the problem. It worked last week before the upgrade:
<?php
if(!isset($_POST['submitCheck']))
  // show form
<html>
<body>
  <form method="post" action="<?php echo $_SERVER['PHP_SELF']; ?>">
    <input name="submitCheck" type="hidden" value="sent" />
    <input name="submit" type="submit" value="Submit" />
  </form>
</body>
</html>
<?php
else
  echo 'form sent';
'submitCheck' always returns false and so the form always shows. Any ideas?
5 REPLIES 5
spraxyt
Aspiring Legend
Fixes: 75
Re: Problem with form submit - was working before
I think the suggestion in the long thread here might help explain the problem. But note that there are important follow up posts later in the thread.
Once you have this working a post here to explain what you did would be helpful.
David
David
ratbag
Thanks a lot David.
The link you provided says the problem is with 'PHP_SELF' and it is. It suggested trying 'SCRIPT_URL'. I quick search suggests it should say 'SCRIPT_URI' but this led me to 'SCRIPT_NAME' which works (currently anyway). If this is not a good idea for any reason I'll just hard-code the file name. Thank again,
Barry.
spraxyt
Aspiring Legend
Fixes: 75
Thanks for the feedback.
'SCRIPT_NAME' includes the /~username prefix, but if it works OK with this variable that's fine. It should have worked with 'SCRIPT_URL' which is the relative path from the HTTP root, excluding the /~username prefix.
David
David
Gabe
Quote from: ratbag
That's confusing me because, as David mentions, _SERVER["SCRIPT_NAME"] will contain the /~username. It would work with GET, but not POST.
Gabe
Ben_Brown
$_SERVER['SCRIPT_URL'] is the correct one to use. We are also looking in to getting it working with PHP_SELF, however if you need the script working ASAP it's best to use SCRIPT_URL.
