Problem with form submit - was working before
- Everything else
- Problem with form submit - was working before
16-03-2010 11:24 PM
I have a problem with form submission. I've made a minimal example to see if anyone can see the problem. It worked last week before the upgrade:
'submitCheck' always returns false and so the form always shows. Any ideas?
<?php
if(!isset($_POST['submitCheck']))
// show form
<html>
<body>
<form method="post" action="<?php echo $_SERVER['PHP_SELF']; ?>">
<input name="submitCheck" type="hidden" value="sent" />
<input name="submit" type="submit" value="Submit" />
</form>
</body>
</html>
<?php
else
echo 'form sent';
Message 1 of 6
(1,371 Views)
5 REPLIES 5
Re: Problem with form submit - was working before
16-03-2010 11:39 PM
I think the suggestion in the long thread here might help explain the problem. But note that there are important follow up posts later in the thread.
Once you have this working a post here to explain what you did would be helpful.
David
David
David
Message 2 of 6
(642 Views)
17-03-2010 12:04 AM
Thanks a lot David.
The link you provided says the problem is with 'PHP_SELF' and it is. It suggested trying 'SCRIPT_URL'. I quick search suggests it should say 'SCRIPT_URI' but this led me to 'SCRIPT_NAME' which works (currently anyway). If this is not a good idea for any reason I'll just hard-code the file name. Thank again,
Barry.
Barry.
Message 3 of 6
(642 Views)
17-03-2010 1:47 AM
Thanks for the feedback.
'SCRIPT_NAME' includes the /~username prefix, but if it works OK with this variable that's fine. It should have worked with 'SCRIPT_URL' which is the relative path from the HTTP root, excluding the /~username prefix.
David
David
David
Message 4 of 6
(643 Views)
17-03-2010 9:23 AM
Quote from: ratbag this led me to 'SCRIPT_NAME' which works (currently anyway).
That's confusing me because, as David mentions, _SERVER["SCRIPT_NAME"] will contain the /~username. It would work with GET, but not POST.
Gabe
Message 5 of 6
(643 Views)
17-03-2010 9:32 AM
$_SERVER['SCRIPT_URL'] is the correct one to use. We are also looking in to getting it working with PHP_SELF, however if you need the script working ASAP it's best to use SCRIPT_URL.
Message 6 of 6
(643 Views)
- Everything else
