Problem with adding SiteWizard feedback form to Force9-hosted site
- Everything else
- Problem with adding SiteWizard feedback form to Fo...
05-11-2007 2:25 PM
I've been trying and failing to add the popular "SiteWizard" php feedback form to my site, hosted on Force9. I get a 405 Method Not Allowed error. Has anyone else managed this successfully? Googling "405 Method Not Allowed" suggests that my problem probably stems from an issue with the location of the php file, read/write permissions for the php file or the use of 'form method="POST"' but I'm by no means an expert in this stuff. Any pointers would be greatly appreciated!
The form itself is at www.garyandming.com/contact-us.html
Cheers,
Gary.
Re: Problem with adding SiteWizard feedback form to Force9-hosted site
05-11-2007 2:29 PM
http://usertools.plus.net/tutorials/
05-11-2007 4:16 PM
05-11-2007 5:54 PM
right, I am going to try and break this down as simpley as possible for you
From what I discover, you're on Force9?
if not, everything I quote with a Force9 Hostname,
can be inter-changed for PlusNet.
(eg: ccgi.plus.net / ccgi.force9.net ..)
from what I found, as Chris has also pointed out, ..
you have the 'feedback.php' file in the wrong place
It was trying to Send Data to the Server, which it couldn't do anything with.
I have also edited the PHP Script as it was basically wide open with Raw EMail Addresses and the works...
I found this was entirely readable from the WWW Server,
this file needs to be placed in the CCGI Server.
Looking at your form and code, you may want to add extended EMail Address Checking as well as string length limitations
Firstly you will need to edit the 'contact-us.html' file for any of this to get off the ground initially ...
'contact-us.html'
<form method="POST" action="http://ccgi.~.force9.net/feedback.php">
<input type="text" name="name" size="30"><br>
<br>
<input type="text" name="email" size="30"><br>
<br>
<textarea rows="9" name="message" cols="30"></textarea>
<br>
<br>
<input type="submit" value="Submit" name="submit">
</form>
At Line 17 and onwards..
The Charater Limits on the Mail Address and Name is not very good, none of my own Mail Addresses would fit those fields. 30 is a good value to use I would have said.
Replace ~ with your Force9 Account Name. example:
http://ccgi.abcd123.force9.net/feedback.php
Save these changes,
and upload the file to your Webspace.
Delete the 'feedback.php'
I advise ..
you alter your 'feedback.php' script as follows -
<?php
//CSV InString Search
function instring($String,$Search){
$Search = explode(',',$Search);
$true = 0;
for($j=0;$j<count($Search);$j++){
if($Search[$j] != ""){
for($i=0;$i<(strlen($String)-strlen($Search[$j])+1);$i++){
if(substr($String,$i,strlen($Search[$j])) == $Search[$j]){
$true = 1;
return $true;
// Display Page Function for Error Handeling & Sucessfull useage...
function display($StrError,$Form){
$HTML .= '
<HTML>
<HEAD>
<TITLE>Gary Crotaz and Ming Yuan | Contact Us</TITLE>
<LINK REL=StyleSheet HREF="http://www.garyandming.com/garyandming.css" TYPE="text/css" MEDIA=screen>
</HEAD>
<BODY>
<DIV CLASS="imagefloat">
</DIV>
<DIV CLASS="bodytext">
<BR>
<H1>Gary Crotaz and Ming Yuan | Contact Us</H1>
<H2>';
if($Form == 1){
$HTML .= '
<p>Please fill in the following form to contact Gary and Ming</p>
<p><B><FONT COLOR = "#FF0000">Error - '. $StrError. '</FONT></B></p>
<p>
<form method="POST" action="feedback.php">
<input type="text" name="name" size="25" value="'. $email_field. '"><br>
<br>
<input type="text" name="email" size="25" value="'. $name_field. '"><br>
<br>
<textarea rows="9" name="message" cols="30">'. $message. '</textarea>
<br>
<br>
</form>
</p>';
}else{
$HTML .= '
<p>'. $StrError. '<p>';
$HTML .= '</H2>
<DIV CLASS="buttons">
<A HREF="http://www.garyandming.com/"><IMG SRC="http://www.garyandming.com/home.jpg" ALT="Gary Crotaz and Ming Yuan"></A>
</DIV>
</DIV>
</BODY>
</HTML>';
return $HTML;
// Your HTML FORM code has a value set which can partially help against
// anyone trying to flood the page with requests
if(isset($_POST['submit']) && $_POST['submit'] == "Submit"){
$to = "x@x.x";
$subject = "garyandming.com contact form";
$name_field = $_POST['name'];
$email_field = rawurldecode($_POST['email']);
$message = rawurldecode($_POST['message']);
//Replaces Enter Spaces(New Lines) with HTML New Line Tags and a trailing CR & LF
$message = str_replace(chr(13). chr(10),'<BR>'. chr(13). chr(10),$message);
$message = str_replace('"','\"'. chr(13). chr(10),$message);
//Validate EMail Address has an @ and . character after the @ character (Extra layer of security)
$Exp = explode('@',$email_field);
if(instring($email_field,'.') == 1 && instring($Exp[1],'.') == 1 && strlen($email_field) > 30){
// Only allow A to Z Characters, reguardless of Case (UPPER or lower)
if(instring(strtolower($name_field),'a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z') == 1 && strlen($name_field) > 30){
//Added HTML Mail Formatting
$body = "From: $name_field<BR>". chr(13). chr(10).
"E-Mail: $email_field<BR>". chr(13). chr(10).
"Message:<BR>". chr(13). chr(10). $message. chr(13). chr(10);
if(mail($to, $subject, $body)){
echo display("Your message has been submitted to GaryandMing!",0);
}else{
echo display("Unable to send message to GaryandMing at this time, Please try again later!",1);
}else{
if(strlen($name_field) > 30){
echo display("name field is too long",1);
}else{
echo display("invalid characters in name field",1);
}else{
if(strlen($email_field) > 30){
echo display("Email address is too long",1);
}else{
echo display("invalid Email address",1);
}else{
echo display("interal error, request incomplete",0);
This should add extra EMail Validation and alittle bit of Error Handeling and other stuff.
Please, find the line where I have blanked out and replace the original email address in the php file.
$to = "x@x.x";
Once you have this saved, you're ready upload.
If you use your FTP client to connect to:
ccgi.force9.net
Login with your Force9 Account Login
Upload the 'feedback.php' file to the folder you see initially.
(This is what we call our "root" or our "home" folder)
Once uploaded, That's the first stage done
Now, Linux / *NIX has file Permissions, what this means is,
our script will only work, if, we give the Permissiosn to,
read & run it (or execute it).
If you right click on the 'feedback.php' file in the FTP Browser,
you should have the Option of "Properties" or maybe
"File Permissions".
In there, you may see a series of 9/12 Check Boxes and/or
a longer text box underneath with:
0644
if you change the value
'0644' to '0755'
then click "Apply" / "OK".
That gives permissions for your username to execute the
'Server Side Script' (The PHP File in this case)
And, all should work
If I have missed anything out or gone too fast,
just ask again and I'll try and break that down.
Jim,
06-11-2007 2:09 PM
Thanks very much for your detailed step-by-step instructions - greatly appreciated. I've adjusted the html and php files as suggested, put the php file in ccgi.[username].force9.net root folder and uploaded the new contact-us.html, then adjusted the permissions of the php file to 755. I'm now getting what looks like a 404 error when it tries to access the php file. Any ideas what I might have done wrong?
Cheers,
Gary.
09-11-2007 12:18 PM
11-11-2007 1:46 AM
I've been trying to sort it out ...
found I've made numerous errors as usual 😕
here is the updated code (Should work now)
<?php
$true = 0;
$true = 1;
return $true;
$HTML .= '
<HTML>
<HEAD>
</HEAD>
<BODY>
</DIV>
<BR>
<H2>';
if($Form == 1){
$HTML .= '
<p>
<form action="feedback.php" method="POST">
<B>Name</B> <input type="text" name="name" size="25" value="'. $name_field. '"><br>
<br>
<B>EMail</B> <input type="text" name="email" size="25" value="'. $email_field. '"><br>
<br>
<br>
<br>
</form>
</p>';
}else{
$HTML .= '
$HTML .= '</H2>
</DIV>
</DIV>
</BODY>
</HTML>';
return $HTML;
if($_POST['submit'] == "Submit"){
$to = "x@x.x";
$subject = "garyandming.com Contact Form";
//Replaces " with double '' incase of breaking the string and injecting code
if(instring($Exp[1],'.') == 1 && strlen($email_field) < 30){
if(instring(strtolower($name_field),'a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p,q,r,s,t,u,v,w,x,y,z') == 1 && strlen($name_field) < 30){
}else{
echo display("Unable to send message to GaryandMing at this time,<BR> Please try again later!",1);
}else{
if(strlen($name_field) < 30){
}else{
}else{
if(strlen($email_field) < 30){
}else{
}else{
Hope all goes well!
Jim,
12-11-2007 12:58 PM
18-11-2007 8:25 PM
21-11-2007 8:16 PM
* Big OOPS on my part I am sorry! *
Right, to correct this problem -
in your contact-info.html file,
on Line 18/19: Change the .net to .co.uk
action="http://ccgi.indium.force9.co.uk/feedback.php"
I forgot that force9 CCGI has .co.uk not .net domain extension.
Hopefully that'll do the trick! xD
Jim,
22-11-2007 3:08 PM
Many thanks for your help with this - much appreciated.
22-11-2007 11:24 PM
Glad its working
anymore problems just gime me a shout
hopefully when my site works anyone will be able to ask there
Jim,
06-12-2007 5:07 PM
The form is posting fine and the error checks work with no problem. However, the contact form takes quite a long time to load - any ideas why this might be? The file size is only about 1kb for the contact-us page and 4kb for the feedback.php file.
Cheers,
Gary.
19-02-2008 8:14 PM
I'm not sure euh, could possibly be the error checking,
but, it may well be the Mail() command, may take time to parse the data.
I haven't yet experimented with the Mail() command on my website yet,
but I will once I get it sorted and allow Users to Register. I may then have an answer but it will be a long time yet.
Hope this helps to some degree.
Jim,
- Everything else
