Printer/Plusnet
Legsnco
Printer/Plusnet
I have good PlusNet internet connection however even though printer connection level is the same the 2 don't stay connected at the same time.
I have uninstalled & reinstalled my printer making no difference at all.
Any suggestions would be most welcome.
Thanks.
2 REPLIES 2
Fixes: 391
Re: Printer/Plusnet
Can you explain how you are connecting your printer, is it wirelessly to the router?
Fixes: 144
Re: Printer/Plusnet
This rather sounds like the printer is connected to the router by WiFi and the WiFi is set to auto channel.
I have seen issues with my Samsung printer which seems to not “follow” a WiFi channel change. The solution which worked for me was to choose a fixed WiFi channel in the router WiFi settings.
