Premise Environment Jargon
FIXED- Subscribe to RSS Feed
- Everything else
- Premise Environment Jargon
10-07-2020 12:49 PM
Can someone please explain what these Premise Environment information mean from the Broadband Availability Checker?
Fixed! Go to the fix.
Re: Premise Environment Jargon
11-07-2020 12:35 PM
11-07-2020 1:39 PM - edited 11-07-2020 1:40 PM
@daveplus I did and it said
VRI
Voice Reinjection Voice re-injection (VRI) is where CPs use a fibre connection to deliver analogue voice services to the customer over their extension wiring. Their equipment will typically include an Analogue Telephony Adapter (ATA) port on their Hub/Router. Think of this like a voice port on each router.
NTE
Network Terminating Equipment. Equipment that is located in the home or office. Examples are set top boxes and LAN.
and I coundn't find the other one (a Bridge Tap) at https://www.openreach.co.uk/orpg/home/aboutus/glossary.do
But I'm not really much the wiser. I was hoping for some simple lay terms
11-07-2020 2:15 PM
@Leapy A bridge tap is usually incorrect wiring in the premises where there is an unterminated branch off the incoming line, also known as star wiring. It can cause reflections that interfere with the xDSL signal giving poor speeds. Having seen your other posts and the diabolical wiring setup that you have with apparently no master socket connected I wouldn't be surprised if you have a bridge tap even though it isn't shown on the checker results. I don't think you got the message from @MisterW in your other thread and I quote "It couldn't possibly have been done by an, even bad, BT engineer." (i.e. no BT employee would have done it) So it certainly was a botched cowboy job.🙄
NTE faceplate is precisely that, is a filtered faceplate installed on the master socket, for my line that test shows the wrong result.
VRI not relevant as it only applies to full fibre (FTTP) where analogue phone signals are sent from the ONT or router to the home phone wiring. This was the BT FVA (fibre voice access) system which I believe is no longer supplied.
11-07-2020 2:46 PM
@RealAleMadrid Concise and plain English too. I'm wiser. Thank you. That's a fix
- Everything else
