Preferred Browser
- Everything else
- Preferred Browser
Preferred Browser
10-11-2017 1:19 PM
Having been reading comments and responses - I just wondered if Plusnet have a "preferred" browser. Personally I use Firefox.
Message 1 of 2
(279 Views)
1 REPLY 1
Re: Preferred Browser
10-11-2017 1:26 PM
I don't think so, it's mainly whether their site works properly on it.
I'm sure it does, and they have tested it.
I assume you're using a PC .. so I would keep it as a backup, so if some part of the site doesn't work you can use Internet Explorer.
Unless you notice a problem, then I don't see a need to worry.
Probably only relevant if you need to ring CS with a problem.
Message 2 of 2
(274 Views)
