Poles with electricity lines
Mister_Roy
Virgin have declined to install full fibre to my property because the only rout is overhead via a pole that has electricity and phone lines. Do Plusnet have a policy on this, no point in me placing an order if they will decline too. My partner had full fibre run from a similar dial-use pole so I’m hoping because Openreach do the install it will be ok ?
13 REPLIES 13
Fixes: 387
Re: Poles with electricity lines
If OR already have facilities on the pole, then I see no reason why they wouldn't install Full Fibre apparatus - providing (a) they provide Full Fibre in the area, and (b) it is safe/possible to add more.
Mister_Roy
One copper line on the pole, which is midway between my house and a fibre-equipped pole in the street. The Virgin surveyor said they didn’t have wayleave to go to a dual pole. My thoughts are like yours, if there’s a copper line on it already, then Openreach must already have wayleave. And if Plusnet use Openreach for install why would there be a problem. However, all search tools for fibre say my house can’t get it, despite it being in the road 25 metres away, but the only cable route is overhead via the dual-use pole, hence my query
Fixes: 387
A good way, and probably the best, to determine whether or not Full Fibre is available to you, is to post the full result from either: https://www.broadbandchecker.btwholesale.com/#/ADSL , or https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome , if you don't have a phone service associated with your current connection. Obscure your phone number/address before posting the result, though.
corringham
Seasoned Champion
Fixes: 23
Quite often OR are reluctant to use dual service poles, as they need specialist teams for the installation (due to the electricity cables) and such teams are in short supply. They may do it if they are actively building an area, but not so likely to do infills.
Fixes: 387
Good point, @corringham . Until we know more from the OP, we won't really know what is happening. Is the 'pole with fibre' an OR one, or an altnet, for instance?
Fixes: 251
Dual service pole require the use of blue ladders which are not carried on all vehicles.
If neighbours in the same post code have fibre but your property does not, there is a possibility that BTOR’s databases are flawed thus a call to Plusnet to explain the circumstances requesting a database integrity check is the way to go.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Everything Else
Marsh
Fixes: 41
Hey @Mister_Roy,
As @Townman as correctly informed, it could be an issue with the BTOR database. I can raise a request for your address. Please send me a direct message with your address so we can proceed.
Josh
Mister_Roy
Thanks, can’t see any option to send a DM on this board ?
Fixes: 387
@Mister_Roy Click on @Marsh 's avatar, select 'send private message'.
Fixes: 251
Or more precisely click on @Marsh 's name link (like the one here) or next to their avatar and click the "Send Private Message" link which could be a button or just text.
Fixes: 387
Apologies for my error.😉
Tina11192
Fixes: 18
Hi @Mister_Roy I hope you are well. I have raised this matter with Openreach regarding checking the database for your address, the reference is QIS***** (for security purpose this has been hidden) and we should be getting some form of response within 5 working days. However, if I receive a response sooner, I will be updating you then.
Cri Ignatti
