Pointing my domain at plus.net hosting
- Everything else
- Pointing my domain at plus.net hosting
17-10-2010 5:16 PM
I have a domain, hosted elsewhere, which I'd like to point at my plus.net web hosting. I assume I can't just set the cname records to a plus.net web hosting IP as the virtual hosting would need to know which site to point it at.
So... where can I setup the plus.net side of the configuration to link my domain name to my hosting space? Thanks in advance.
Message 1 of 2
(904 Views)
1 REPLY 1
Re: Pointing my domain at plus.net hosting
17-10-2010 7:12 PM
You just need to follow the instructions for 'Hosting Only" transfers:-
http://www.plus.net/support/hosting/domains/domainin.shtml
Quote Ask your domain provider to change the name servers of the domain you want to transfer to:
ns1.force9.net
ns2.force9.net
This process usually takes between 12-24 hours.
When the name servers have updated (you can check this using Whois), use the following Help Assistant path to raise a hosting request:
Technical Support > Domains & DNS > Transfer a Domain In > Hosting Only (any domain)
Your domain will be up and running 8-12 hours after your request is processed.
Message 2 of 2
(189 Views)
- Everything else
