Pointing my PN domain at my CCGI space.
- Everything else
- Pointing my PN domain at my CCGI space.
09-07-2009 10:08 PM
Have updated my domain DNS records as follows:
Additional DNS records (Advanced)
Left field Type Pri Right field
mx 20 mx.last.plus.net.
www cname ccgi.plus.net.
However it does not work. IS there anything else I need to do? Should it update straight away?
Should the "Domain Hosting Settings" be changed from default to "Other"
Message 1 of 5
(1,262 Views)
4 REPLIES 4
Re: Pointing my PN domain at my CCGI space.
09-07-2009 11:21 PM
How many hours have you waited before trying it? DNS changes take some time to propagate.
Message 2 of 5
(356 Views)
09-07-2009 11:29 PM
I suspected that might be the case, however I found it odd that the page did not mention the rather important bit of information.
Message 3 of 5
(356 Views)
10-07-2009 10:12 AM
After leaving it overnight, it's not worked, my Plusnet domain name is still pointing at my regular webspace.
How can I get it to point to my CGI space?
Thanks.
Thanks.
Message 4 of 5
(356 Views)
20-07-2009 1:15 PM
The right field should be ccgi.your plusnet username.plus.com.
MAKE SURE you include the . at the end of com
Message 5 of 5
(356 Views)
- Everything else
