Pointing digitalbuddy.co.uk to www.digitalbuddy.co.uk in Configure DNS
- Everything else
- Re: Pointing digitalbuddy.co.uk to www.digitalbudd...
21-01-2014 9:08 PM
I've been scratching my head about this for ages, and can't seem to figure it out...
I recently moved DNS Management of a website that I used to host with Fasthosts over to my ISP, Plus.net, but I've been having a hell of a time trying to configure my DNS. I'm almost there, but the only thing I'm left wondering, is how should I modify my plus.net DNS Configuration to point http://digitalbuddy.co.uk to http://www.digitalbuddy.co.uk ; ?
Thanks for any help,
Christopher
Christopher
Message 1 of 6
(1,230 Views)
5 REPLIES 5
Re: Pointing digitalbuddy.co.uk to www.digitalbuddy.co.uk in Configure DNS
22-01-2014 9:06 AM
AFAIK that's an A-record. You'd need to enter http://digitalbuddy.co.uk in the left hand field and add the IP of the hosting server (which I can see you have set up on other DNS records) in the right.
There's a tutorial here in case that helps: http://usertools.plus.net/tutorials/id/14
Message 2 of 6
(594 Views)
22-01-2014 1:48 PM
A thousand thanks for that Adam. That link you forwarded is very useful, and you could do with putting it somewhere on the configuration screen because what's there is a little unclear, to me at least.
Thanks again!
Thanks again!
Message 3 of 6
(594 Views)
22-01-2014 2:28 PM
Message 4 of 6
(594 Views)
14-04-2014 1:34 PM
I tried to do this but get an error message:
. - a-z 0-9 are allowed in the left field
Which seems to mean the // in http:// isn't allowed. The hosting company I use has a * to cater for everything but as per that error message I can't use that either. Should I just put the domain name on the left without anything in front?
Message 5 of 6
(594 Views)
14-04-2014 2:05 PM
Just enter the fully qualified domain name (followed by a dot) without the protocol http:// . DNS is concerned only with domain names and IP addresses.
Your browser uses HTTP to connect to the server; for FTP it could be ftp, but the IP address provided by DNS would be the same.
David
Message 6 of 6
(594 Views)
- Everything else
