Plusnet's Pay As You Host Platform
- Everything else
- Re: Plusnet's Pay As You Host Platform
09-11-2013 8:11 PM
Thanks Iain
09-11-2013 8:43 PM
09-11-2013 9:52 PM
Gabe
09-11-2013 11:12 PM
I have changed some of the questions in the poll but for some reason it will not let me change everything i want I will try again later,the reason for the poll is that i want plusnet to upgrade the PAYH platform to something higher plesk 9.5 is near end of life but still a good platform even if they would update the install script for the Web Applications that would help so much.
Iain
10-11-2013 3:28 PM
Experiences with the ccgi platform are that it's not easy to get anything more than very basic scripts to work properly on it, because the settings are unlike any other I've seen. (Even an Options -Indexes in .htaccess bombs the site out with a 500!) That said, the ccgi platform is a bonus feature on a comms package, and is reasonable in that respect. If a webdesigner (like me) is paying for hosting it has to work properly though, and ccgi-type space would not be acceptable in that role.
10-11-2013 3:43 PM
Quote from: Anteaus Even an Options -Indexes in .htaccess bombs the site out with a 500!
There's no override for Indexes, but Indexes is already off in conf.
Gabe
10-11-2013 3:57 PM
Thanks for taking the time to reply and giving the views of a web designer, are you using your US-based hosting company to host uk based sites ie .co.uk
your comments about the cgi platform are interesting anyone else got any comments I would like to hear them.
Iain
10-11-2013 5:50 PM
10-11-2013 5:56 PM
Quote from: Gabe There's no override for Indexes, but Indexes is already off in conf.
Gabe
Hardly the point, as -Indexes is a standard security setting for many packages. Thus, this is just one of many ways in which a standard setup has to be modified to run on ccgi space.
I might add that a key problem with ccgi seems to be that php returns a script_filename value of /~accountname /index.php instead of /index.php. Yet, if a script tries to access /~accountname/index.php this will fail. This seems to be the reason a great number of commercial packages fall over on ccgi. You can sometimes get around this by forcing a webroot value of / in the settings.
11-11-2013 4:09 PM
Quote from: Anteaus Hardly the point
I think my point is that the ccgi conf setting for Indexes follows a normal recommendation for hardening Apache. It's not unusual. The fact that some CMSs set things like -Indexes and +FollowSymLinks as defaults in their .htaccess files, rather than as commented-out recommendations, and this breaks on some correctly-configured hosting platforms isn't really a valid criticism of the platforms but of those CMSs. The fix is trivial.
I don't think I've met a standard setup. ccgi is, or was, a rather nice example of its sort.
Quote php returns a script_filename value of /~accountname /index.php instead of /index.php.
No it doesn't.
While I think ccgi was originally conceived as a scripting addition to homepages, I know quite a few people have successfully run a range of CMSs on it. At present, I think the main obstacle these users encounter is the available version of MySQL. The lack of updates is a real issue. Over the years, other issues have been associated with the loss of shell access and the daily bandwidth limit.
Gabe
12-11-2013 1:35 PM
Parallels Plesk Panel 9 Released December 9, 2008
Extended Support December 9, 2012
End of Life & Support June 9, 2013
So unless plusnet have a special deal with Parallels it's no longer supported i know some other host still run plesk 9 but have announced that they are ore about to upgrade to 10 or 11
This is the response i got from plusnet "I'm afraid there's no plans for an upgrade at present, sorry about that. There'll certainly be a service status posted if any changes are due to be made though, you can see those at servicestatus.net." thanks Matt for the reply(I know you are just the messenger in this case)
I would off though plusnet would of had short medium and long term plans for all their products the lack of any informations makes things difficult for us not knowing what's going on in the medium longer term.
Iain
13-11-2013 11:00 AM
Quote from: Gabe
No it doesn't.
I can assure you that it does, on my account anyway. Just spent some time hacking an app's paths to work around this.
Unfortunately, thought I'd solved it and had the main part of the app working OK but then found that it still crops-up in a few more places I hadn't anticipated.
13-11-2013 11:45 AM
Has anyone one got anything higher than WordPress v2.8.4 to run on plusnets PAYH / or on the free space allocated to ccgi users, if that at all possible the reason i ask is if i were able to run the latest version of wordpress on PAYH that would solve half my problems
Thanks Iain
13-11-2013 3:46 PM
Quote from: Anteaus it does
SCRIPT_FILENAME != SCRIPT_NAME
Gabe
13-11-2013 3:48 PM
Quote from: Iain03 anything higher than WordPress v2.8.4 to run on plusnets PAYH
I haven't tried it, but I think you should be able to run up to 3.1 on PAYH.
On ccgi you can run the current 3.7.1, using this script to install it. There may be problems with some plugins (as ever). I don't know for how long this workaround will continue to work.
Gabe
- Everything else
