Plusnet protect free or not?
ah
It used to be free but now I see that it is £2/month which makes it £24/year, i.e. almost the same as buying it directly from McAfee.  What is the point?  Has anyone else noticed this new policy?
22 REPLIES 22
Oldjim
Fixes: 63
Re: Plusnet protect free or not?
It is still free on unlimited and unlimited extra fibre https://www.plus.net/home-broadband/protect/
Having said that I wouldn't recommend it
ah
No: first 3 months free then £2/month
Oldjim
Fixes: 63
not on the two products I listed - check the link
Browni
Aspiring Hero
Fixes: 60
Only on Unlimited Fibre, see @Oldjim's link.
VileReynard
Fixes: 20
I've never used a program purely designed to waste CPU cycles.
ah
I did.  It's on your link that I saw that it was only free for 3 months.  Just scroll down the page and you'll see
Oldjim
Fixes: 63
Browni
Aspiring Hero
Fixes: 60
ha! beaten by @Oldjim and he put a box round his Grin
ah
Yes and on the right hand side under unlimited fibre I read: first 3 months free then £2/month
Oldjim
Fixes: 63
So what did I say in my first reply
ah
You wrote: 'It is still free on unlimited and unlimited extra fibre'  I have unlimited fibre and:
VileReynard
Fixes: 20
I can do better - since I took out 80/20 in 2012, I'm not liable to any price increases (according to the small print).
Oldjim
Fixes: 63
Which is precisely correct
There are three products and this is the Plusnet Protect Costs
Unlimited (which is ADSL) - free
Unlimited Fibre - not free
Unlimited  Fibre Extra - free
Browni
Aspiring Hero
Fixes: 60
Unlimited is an ADSL package...
