Plusnet now charge us to ghost call or mobiles
Fixes: 116
Re: Plusnet now charge us to ghost call or mobiles
I'll test it by all means but it will take a few days for the results to come in Smiley
 Jono H
 Plusnet Community Manager
Fixes: 116
This has been tested, so for the avoidance of all doubt, Plusnet does not charge for calls to mobiles that you don't answer, that are not diverted.
If you're being charged then your line is connecting, probably to its voicemail.
 Jono H
Fixes: 149
Thanks for testing that @JonoH  Did you just test calls to PN mobile or other networks as well ?
Thank you JonoH,
Fixes: 116
PN, EE and Voda were tested (Thats what I had access to at the time)
 Jono H
Fixes: 28
FWIW called my EE mobile over 48 hours ago (unanswered) and nothing on Plusnet itemised bill.
Thought that would be the case, as like the OP I do occasionally call it to hear it ring when I've mislaid it somewhere in the house.
Ω is where the is
