Plusnet Support Saying it Expires Every Month
FIXED- Subscribe to RSS Feed
- Everything else
- Re: Plusnet Support Saying it Expires Every Month
07-03-2018 9:27 AM
Hi
Every month since I have moved to Plusnet the Plusnet Protect expires and needs to be reloaded. Does this happen to everyone or is there an issue with my account? Can it be resolved? Last month I contacted the support and they said to reload it, which I did and now it has expired again. The support people last month said they didn't know why it expires every omnth so I am confused.
Can anyone help to resolve as it is a pain every month to reload it.
Fixed! Go to the fix.
07-03-2018 11:47 AM
07-03-2018 12:27 PM
Thanks Matt, I got an email saying it had been cancelled and I have to uninstall all software and if I want to protect my pc again I'd have to select Plusnet Protect in add ons and basically start the whole download and installation process again? Not ideal to have this every month, thought it would roll over as with any other provider?
07-03-2018 3:50 PM
This problem occured several times back in July 2017 an finally resolved 12/12/2017. See this thread: https://community.plus.net/t5/My-Account-Billing/Plusnet-Protect-Problems-McAfee/m-p/1453731 and particularly @Gandalf post #12. HTH
07-03-2018 4:03 PM
Hi there.
Plusnet Protect works on a month by month basis, and every month it should auto-renew.
One of my colleagues has had a look into this and unfortunately the cancellation for the previous month is completing after the provide for the new month, which stops the software from working.
To resolve this, we've wiped the Plusnet Protect installation clean from your account.
If you uninstall the software then download and install a fresh copy one more time, you shouldn't experience this issue again. My colleague will be sending you an e-mail with instructions.
Hope this helps.
07-03-2018 4:53 PM
I have done all this and it seems to have worked, so thanks. Will I need to uninstall and download it on all other devices I have it installed on or will they automatically be OK?
Sorry if that's a stupid question!
07-03-2018 4:57 PM
- Everything else
