Plusnet Protect Security Software
- Everything else
- Plusnet Protect Security Software
11-02-2017 11:07 AM
I have received updates this morning for the McAfee / Plusnet Protect Security Software that are causing Google Chrome, Mozilla and Edge to crash
Re: Plusnet Protect Security Software
11-02-2017 11:23 AM
Just tried uninstalling and reinstalling it gives the same error
ill try uninstalling and using the Mcafee removal tool at http://us.mcafee.com/apps/supporttools/mcpr/mcpr.asp
then reinstall and see if its the same,
11-02-2017 11:36 AM
I just use Windows Defender built in to win10 👍
And Malwarbytes , can't go wrong
11-02-2017 11:44 AM
after a bit of messing around it seems the McAfee WebAdvisor that i don't use was crashing all browsers when this is removed its working fine, its the same issue with BT net protect
11-02-2017 12:19 PM - edited 11-02-2017 12:20 PM
That's why they give it for free
11-02-2017 2:23 PM
When I upgraded to fibre broadband the PN adviser told me it's not worth using the free tools if I already have anti-virus software. Like others here I just use Windows Defender and run a scan now and then with MalwareBytes free software.
McAfee was never very good and it seems everyone gives it away these days so there's no incentive for McAfee to make the program any better.
11-02-2017 3:16 PM
I'm with rongtw on this one.
BT Netprotect plus was a total pain imho, it was very resource hungry (it used to s-l-o-w devices down by robbing all the processing power) and often caused more issues than it fixed.
Having not allowed PNP anywhere near our devices, I couldn't possibly comment.... ..... but I did even go to the point of uninstalling McAfee* from a brand new laptop purchased in January
*Mr McAfee himself has bad mouthed products that he had sold on to A.N.Other via a well known video he once uploaded.
W7 = MSE (Microsoft Security Essentials) = free
W10 = Windows Defender (looks the same as MSE) = free
Malwarebytes = free version
CCleaner = free version
Spybot search and Destroy = free version
I have no commercial interest in any of the above, but I learned my lesson the hard way!!
- Everything else
