Plusnet Protect (McAfee Anti Virus)
adrian_k
Just reinstalled Windows7 and tried to re-install McAfee but I'm receiving an error message about mcmscins.dll not being designed to run on Windows.
I've tried the McAfee software removal tool (MCPR.exe ) but that wasn't successful either.
any clues on how to fix this?
thanks
Adrian
7 REPLIES 7
Pete11
Seasoned Pro
Fixes: 4
Re: Plusnet Protect (McAfee Anti Virus)
Try here...the download is on the right hand side at the top.
http://www.dll4free.com/mcmscins.dll.html
Or re-install Mcafee 2012
A float tip is pleasing in its appearance and even more pleasing in its disappearance.
Growing old is inevitable...But growing up is optional.
rongtw
Fixes: 12
There is another option ,, Use another free AV you dont have  to use McAfee Thumbs_Up
adrian_k
Pete,
Thanks for the link but it didn't work.  I put the dll in the system folder as it suggested and also tried the temporary installation folder of McAfee but still got the same message,
Adrian
Pete11
Seasoned Pro
Fixes: 4
Then I suggest you take up rongtw's advice and install a different AV. Something like Avast or AVG.
Browni
Aspiring Hero
Fixes: 59
Looking at the screenshot in the op it looks like a bad download of McAfee so I suggest re-downloading and trying again.
adrian_k
hi All,
It's fixed & I think I know why.  I reinstalled Windows7 and the existing system was archived to a directory called Windows.Old.
While housekeeping and finishing the installation, I deleted the the old install and \program files\ and also re-downloaded (again) the installer.
Seems that through a combination of the above it cleared the issue and MCAfee installed without a problem,
cheers,
Adrian
Pete11
Seasoned Pro
Fixes: 4
Glad to know it's all sorted. Thumbs_Up
