Plusnet Protect (McAfee Anti Virus)
- Everything else
- Re: Plusnet Protect (McAfee Anti Virus)
18-08-2017 5:49 PM
Just reinstalled Windows7 and tried to re-install McAfee but I'm receiving an error message about mcmscins.dll not being designed to run on Windows.
I've tried the McAfee software removal tool (MCPR.exe ) but that wasn't successful either.
any clues on how to fix this?
thanks
Adrian
18-08-2017 6:00 PM - edited 18-08-2017 6:04 PM
Try here...the download is on the right hand side at the top.
http://www.dll4free.com/mcmscins.dll.html
Or re-install Mcafee 2012
Growing old is inevitable...But growing up is optional.
19-08-2017 7:15 AM
There is another option ,, Use another free AV you dont have to use McAfee
19-08-2017 8:03 AM
Pete,
Thanks for the link but it didn't work. I put the dll in the system folder as it suggested and also tried the temporary installation folder of McAfee but still got the same message,
Adrian
19-08-2017 11:08 AM
Then I suggest you take up rongtw's advice and install a different AV. Something like Avast or AVG.
19-08-2017 11:18 AM
25-08-2017 2:03 PM
hi All,
It's fixed & I think I know why. I reinstalled Windows7 and the existing system was archived to a directory called Windows.Old.
While housekeeping and finishing the installation, I deleted the the old install and \program files\ and also re-downloaded (again) the installer.
Seems that through a combination of the above it cleared the issue and MCAfee installed without a problem,
cheers,
Adrian
25-08-2017 4:31 PM
Glad to know it's all sorted.
- Everything else
