Plusnet Protect - A requirment
Shoeless
I've just read the T&Cs that came with the notice of my Unlimited Fibre which starts today.
What alarms me is this bit.
. Plusnet Protect must be kept for at least 30 days.
This appears to be a requirement that I put on a McAfee product on my machine.   There was no mention of this when I rang up for fibre and there is no way that I would remove my current malware suite for this one.
What does this requirement mean?
Is this something that Plusnet hope that I overlook and so can charge me extra per month?
Can someone advise me what this means please?
5 REPLIES 5
Mav
Fixes: 515
Re: Plusnet Protect - A requirment
Moderator's note:
Thread moved from Fibre Broadband to Everything Else.
Forum Moderator and Customer
rongtw
Fixes: 12
As a new customer Plusnet protect is free for first 3 months the £2 a month https://www.plus.net/home-broadband/protect/ Thumbs_Up
There is no requirement for you to use it and you can uninstall at any time , the 30 days would refer to your billing cycle
Shoeless
Thanks.  I will put a note in my diary to do something towards the end of June.
It's not the £2 that I object paying: it's the two pounds going towards a McAfee product that I object.
spraxyt
Resting Legend
Fixes: 75
As said earlier Plusnet Protect is an option for you to install and use if desired. There is no requirement to download or install it but if you do it has to be kept for 30 days.
If you prefer to provide your own protection that's fine.
David
Fixes: 1,600
Hi there.
From what I can see Plusnet Protect isn't added to your account so you don't need to worry about being charged for it.
This basically means that it's added and removed on your billing date if requested.
