Plusnet Mastercard - no PIN number/contactless?
- Everything else
- Plusnet Mastercard - no PIN number/contactless?
30-07-2023 5:03 PM
Re: Plusnet Mastercard - no PIN number/contactless?
01-08-2023 6:27 PM
Hey there @LA1 whilst we are unable to advise about the PIN I just want to check, if you call the number on the card they will be able to advise, have you tried that?
08-08-2023 2:10 PM
Hi.. only just seen your post..
I had a card with a positive balance from Plusnet too (join up reward) These card with credit have been similar to others I have had.. they don't operate like normal credit and debit cards.
I have used them eventually but it has not always been easy on the things I wanted.
As the other reply said.. check the card supplier website. You should have a pin number supplied with the card for the website
- Everything else
