Plusnet Hub One and VPN
- Everything else
- Plusnet Hub One and VPN
on
29-10-2020
5:10 PM
- last edited on
09-11-2020
7:08 AM
by
Mav
I am thinking of signing up to Cyberghost for VPN Is this compatible with my Plusnet Hub One router? If so what does a thickie have to do?
Re: Plusnet Hub One and VPN
09-11-2020 7:10 AM
Thread moved from Fibre Broadband to Everything Else.
Forum Moderator and Customer
09-11-2020 7:59 AM
If you plan on installing the VPN on a device behind the router then it will be fine. If you're wanting to configure the VPN on the router itself though , so it applies to all of your device at once, then no - the Hub One does not natively supporrt this.
- Everything else
