Plusnet Free Website space - Access problem
shutter
Fixes: 65
I have a website http://www.nemosphotography.co.uk/  hosted on Plusnet FREE WEBSITE SPACE.
I want to do some updating and other work on it... but have forgotten the user name & password..
Is there any way that PN can give me a "reminder" so that I can again access it via the FTP client ?
10 REPLIES 10
Strat
Fixes: 565
Re: Plusnet Free Website space - Access problem
Moderators Note
This topic has been moved from Tech Help to Everything Else to raise its profile.
RobPN
Fixes: 13
@shutter
It's ages since I played around with my PN free webspace and haven't got my present FTP client set up with the details needed to login, but ISTR that many years ago we had to use the same password for everything, i.e. Internet connection, email and FTP.
That may well have changed or I could be plain wrong.
Probably a silly question, but have you tried your standard password?
RobPN
Fixes: 13
@shutter
Just a followup ...
I just successfully logged in to my PN webspace using the following;
Host;   ftp.plus.net
Username:   My plusnet 'accountname'
Password:    My 'standard' PN password
Edit:   Although perhaps it's different for hosted sites such as the one you refer to in your OP   Undecided
Fixes: 393
@RobPN AFAIK ftp access to the free website space is always via the main account username and pw. If a domain is pointed to it it makes no difference.
@shutter the ftp details are shown in the member centre under manage account, manage your web space,  standard web space ( unless it ccgi space! )
shutter
Fixes: 65
@MisterW  & @RobPN  Thanks for your input.... I just got home , and see your responses... so I tried it... but not gaining access..
and checking on the Quickconnect down arrow...
Even if I uses   ftp.nemosphotography.co.uk
So... it`s looking like I have a "password problem"....( although I have not changed it since I started with PN ! ! !  )
Mook
Seasoned Champion
Fixes: 9
@shutter What about what I said in my email?
shutter
Fixes: 65
@Mook   OK... will email you or PM  ? ? ?
Mook
Seasoned Champion
Fixes: 9
I've sent you another email.
shutter
Fixes: 65
@Mook   just sent a P.M to you !
shutter
Fixes: 65
Thanks to @Gandalf
resetting the password has solved the problem SmileyWink
@Mook    @MisterW     @RobPN    @Strat
