Plusnet Broadband portal not displaying correctly
TLM
Re: Plusnet Broadband login and Firefox Browser
I have no knowledge of original versus "new" issue, as I've only witnessed the one, which this thread does appear to be about. Although the implication of the title that the issue is confined to Firefox is incorrect, as it's happening for me on Chrome.
Fixes: 236
There are two issues being discussed in this thread.
  1. Issues logging into the user portal - that issue was specific to FF users
  2. Experiences where on some pages in the user portal, the pan-Plusnet websites black / grey footer appears in the middle of the page obscuring what should be there ... which after resizing the browser window renders in the right place - that is seen on various browsers
So, this being / not being an issue with FF all depends on when you joined this bus.  My observation is that when something goes wrong accessing websites, FF appears to be involved in more "street fights" than all of the other browsers but together.  The phrase "a can of worms" readily comes to mind.
staley84
Still shouldn't be marked as fixed though.
Fixes: 334
As I stated previously, the original incident was fixed. The current issue, which should be in its own topic, isn't.
Fixes: 236
@staley84
That’s a matter for the originator of this topic / thread to decide - and no one else.
staley84
I'm merely suggesting that the 'fixed' status should be removed if possible.
Fixes: 334
Again, the original issue was fixed - the new one should have been in its own topic.
halbot
I created a new one and the mods closed it and referred it to this one!
Fixes: 334
They shouldn't have - different issue. I will suggest the new issue is split off.
Fixes: 1,491
Moderators Note
Posts split as it's a different issue.
staley84
@dvorak What's it been split to?
Fixes: 334
staley84
Thanks @jab1 .Got a bit confusing as the 'New' post (this) has the same name and comments as the 'old' fixed post.
Fixes: 1,641
@staley84@TLM@halbot@RichT
Your accounts have been passed across to the right team to help with this investigation (IMT-8126)
Sorry for the inconvenience everybody.
UnicycleTallPau
This problem was reported a week ago and PlusNet still haven't fixed it. I need to report a separate issue but I can't access the portal properly to do so!.
Just to confirm (yes this is a me too because I don't believe this is fixed yet) FireFox, Chrome, and Android all show the same blank grey page instead of the pink page with account options. Exactly as the OP posted in their image.
