Plusnet Broadband login and Firefox Browser
Legend
Fixes: 255
Re: Plusnet Broadband login and Firefox Browser
Blimey that's a long bugfix list.😅
SpendLessTime
Fixes: 86
@bobpullen wrote:
Testing past and future versions: -
104.0.2 - OK
105.0.0 - Fails
105.0.1 - Fails
106.0b7 - OK
I'm none-the-wiser as to what is actually happening but that ^ suggests we could be looking at an issue in the Firefox domain.
So why did it only start to fail sometime after 29th September when I had already been using V105.01 for a week and had no issues on the 28 and 29th getting into the Member Centre?
SpendLessTime
Fixes: 86
And just for fun, Firefox has just this second updated to 105.0.2 and the issue still persists.
Will await the v106 when it is ready for normal use.
stevel59
I appreciate the logic of this suggestion but why can I successfully log into all my other web accounts in this version of FF?
Legend
Fixes: 255
Good point, @stevel59
bobpullen
Fixes: 316
Do the timestamps behind this button tally for you? (it's found under the 'General' section of the Settings dialogue): -
bobpullen
Fixes: 316
I have no idea and anything at this stage is pure conjecture without understanding specifically what is causing the behaviour.
Not all login forms are equal mind you.
SpendLessTime
Fixes: 86
@bobpullen Yes dates line up
Firefox 105.0.1 (20220922151854)Details
Installed on: 24 September 2022 at 08:29:15Status: The Update was successfully installed
And I logged in on the 28th to get my September bill and the 29th to check my "upgrade options" to help a user who was asking why Member centre offers were £2 more than New Customer prices
edit to add name
bobpullen
Fixes: 316
@SpendLessTime - And you didn't get offered 105? i.e. not the dot version? Possible, as I know Firefox pulled it mid-deployment due to a bug.
Edit: Ignore me, that's completely irrelevant ^
supernoodles
Just had an update to 105.0.2 still not working sadly
nursemorph273
Just confirming I am also having the same issue....can't login to the Member Centre yet, strangely, can login into webmail without a problem. Am also on 105.0.2 since yesterday
bobpullen
Fixes: 316
Might have spotted a problem at this side and we're looking into it. Just thought I'd keep folk updated to avoid any further effort from people trying to work out what has broken.
Edit: issue identified and should be working now. Apologies for the hassle/confusion.
kdiment
I can confirm that you seem to have solved the problem!
Fixes: 419
Yep, it's working for me.
borderpath
Thanks to whoever sorted this issue - much appreciated. All fine with FF now.
