PlusNet OpenWRT 18.06 VDSL Configuration / Settings
- Everything else
- Re: PlusNet OpenWRT 18.06 VDSL Configuration / Set...
17-07-2019 9:16 PM
I am looking for the complete settings for establishing an authenticated connection using the following Firmware:
OpenWrt 18.06.2
Ive attached the options that i require the correct VDSL Settings for.
Can anyone assist? This one has stumped me a little. I get Sync, though i get an error on Authentication, though my Authentication / Handshake should be correct. Though im guessing its something simple that i have just overlooked.
Any help is appreciated.
Re: PlusNet OpenWRT 18.06 VDSL Configuration / Settings
17-07-2019 9:55 PM - edited 17-07-2019 9:57 PM
Finally, all sorted. It was a simple setting looking me right in the eye; ironically.
If anyone would like the precise UK PlusNet configuration settings, i will post them, though in my attachments all the settings are correct. Im just making some fine tuning before going 100% Live.
All this just to allow me to use my own Secure DNS Servers.
06-10-2019 9:29 AM
If anyone would like the precise UK PlusNet configuration settings, i will post them.
I would like to receive the precise settings.
09-10-2019 9:03 PM
@R2000 There's been a request (as above, from @azeu666). Just flagging this up in case you might not have noticed that post.
- Everything else
