Plesk Updates?
- Everything else
- Plesk Updates?
Plesk Updates?
17-02-2009 4:33 PM
Are there any plans to update newer versions of the plesk platform software?
The reason I ask is, I've just discovered PHP Surveyor which I thought was a brilliant piece of software.
Since using it, i've found ALOT of issues/bugs which I didnt like.
Since then, ive installed LimeSurvey which is almost like for like, but without the issues/bugs.
Not only that, its a platform continually being developed.
Speaking with the Developer, im told its a web application with the lastest version of plesk, which made me wonder
Message 1 of 2
(1,399 Views)
1 REPLY 1
Re: Plesk Updates?
17-02-2009 4:43 PM
Hi
I can confirm that we will always be keeping the Plesk platform up to date, it will be roughly 3 updates behind, as by then bugs of the new versions will generally be fixed and the less bugs the better
Message 2 of 2
(136 Views)
