Please can we get updated PHP?
- Everything else
- Please can we get updated PHP?
03-12-2008 4:24 PM
None of the applications we're looking at can run on such an old system.
Im looking for a modern/presentable Open Source commerce platform. OS Commerce just looks too old, there isnt many other applications available
Re: Please can we get updated PHP?
03-12-2008 4:33 PM
It's something we are looking at and making some progress on. Have a look at the blog here for more details.
03-12-2008 4:48 PM
So to get this straight in my head (im not tech savvy), Data will be physically moved from plusnet servers to Plesk servers, the DNS names will be changed to point to the Plesk servers.
So hopefully the outcome will be my User Forum which uses SQL at the backend will still talk to the front end CGI without me having to make any modifications? (providing ccgi.username.force9.co.uk is found on the plesk servers?
04-12-2008 10:29 AM
I just came across your post after posting something broadly similar here: http://community.plus.net/forum/index.php/topic,69283.msg566700.html#msg566700. Perhaps we are having similar problems.
04-12-2008 6:23 PM
If you follow the instructions there, you can set that up and take advantage of the newer version of php now.
Ian
07-12-2008 4:43 PM
I'm sure we're all nice people here, but, if you're on the same server as I am, I can read and write to your PHP-generated files and you can read and write to mine.
I'm sure Plusnet will fix this at some point. I hope it's soon.
Gabe
07-12-2008 10:57 PM
I'm not saying we won't offer those things in the future, but I can say for sure that they won't be free!
Ian
07-12-2008 11:41 PM
Quite apart from anyone wanting to run a shop on PAYH, there are people running children's nursery sites on PAYH. Do you really find the current state of security acceptable?
Gabe
08-12-2008 11:12 AM
Ian
10-12-2008 11:17 PM
I might be completely wrong, but I read Gabe's comment as suggesting that they feel the whole PAYH platform is unsafe, and that they could prove it, by adding a file to your webspace from their own webspace account. If I am right in that, then they are asking for your permission to prove that vulnerability by posting a text file into your webspace (as a proof of concept).
Of course I might have got the wrong end of the stick completely, in which case, ignore my mad ramblings!
Mike
11-12-2008 10:40 AM
You got the right end of the stick, but after sending Ian a more conventional message the point was accepted and acted upon without the need to prove it.
With safe mode off, unless other measures are taken, it opens up a straight-forward way to bypass the open_basedir restriction, allowing users to write to each other’s directories while only changing the mod date on Apache-owned files, which you might not notice.
I had originally assumed that these other measures had been taken, then discovered that they hadn’t, and finally the penny dropped that people were going live with sites that should be more secure, so I made a fuss.
Safe mode is now back on. I hope this is only temporary. IMHO, one or other of the methods for running PHP as the individual user rather than Apache would be the best solution.
Gabe
- Everything else
