Ping times
OryxCallotis
Ping times
My ping times to 8.8.8.8 are typically around 16ms or so, today they're around 30ms or so. My neighbour had some issues with a dodgy appliance yesterday, and it made the power cut at the circuit quite a bit before he figured it out (probably 10-20 times over the day), would this constant loss of power to the router have something to do with the ping increase? I know it doesn't sound like much, but it's a little noticeable in gaming, and I'm only really with PlusNet because I want a low-stable, ping.
Is there possibly something on the line that a staffer could look at? Thanks.
3 REPLIES 3
willcutforth
Fixes: 99
Re: Ping times
Hey there @OryxCallotis I have found a fault on the line which is external so I have sent my minions out to fix it for you. Give it until 05/10/23 23:59:59 and if not resolved, let me know.
 Will Cutforth
OryxCallotis
Re: Ping times
Thanks.
I'm not *quite* 100% sure if the fault you can see is an actual line fault or it's because of the phone line mix-up that I asked about in the other topic (or my order for FTTP). Happy to wait anyway, cheers.
willcutforth
Fixes: 99
Re: Ping times
Oh no it's an exchange fault so we are on it now looking to resolve it Smiley
 Will Cutforth
