Php info
chrisandaud
Php info
Please can someone point me in the right direction to find out the modules available in php?  phpinfo() is disabled for security reasons.  I have tried to use password_hash() and password_verify() but they are not available.  As I spent some time developing my site at home before uploading it this was time wasted.  I'd like to avoid that in future.
Incidentally I raised a ticket asking this question and was told not only that support couldn't help but they couldn't suggest anyone who could!
Any help appreciated.
5 REPLIES 5
chrisandaud
php error_reporting(0);
Does anybody know why error_reporting(0); seems to have no effect on php sites in free webspace and both my error handler (set using $old_error_handler = set_error_handler("userErrorHandler");) and my exception handler (set using $old_exception_handler = set_exception_handler('handleException');) fail to execute?  When I test by inserting a call to a nonexistent function I get a page with no header and a body containing Fatal error: Call to undefined method ....
Strat
Fixes: 565
Re: php error_reporting(0);
Moderator Note by Dick (Strat)
PHP topics merged.
spraxyt
Aspiring Legend
Fixes: 75
Re: Php info
You can find out which extensions have been loaded by calling the get_loaded_extensions function. and printing out the returned array yourself. The linked PHP manual page provides an example for dumping this. You need to wrap the dump output in <pre> ... </pre> tags for line-by-line display.
To get PHP errors to display you need to turn display_errors on and set error reporting to  32767 in .htaccess. Note:please check names; this post is from memory, I'm currently installing apps after doing a clean install of W10 on my PC. My reference files are still on backup media.
The mods have merged both your questions into the one file which makes answering easier. If more questions crop up postthem in this topic. Smiley
David
spraxyt
Aspiring Legend
Fixes: 75
Re: Php info
Having retrieved my files from backup I can confirm the .htaccess settings you need are
php_value display_errors 1
php_value error_reporting 32767
These need to go in  the .htaccess file in /public.
David
chrisandaud
Re: Php info
Many thanks, spraxyt for the quick helpful pointer to an area of php I had completely overlooked in my self-tuition.  It is what Donald Rumsfeld once called an "unknown unknown"!  Now at least it is a known unknown and by the end of the day I hope it will be a known known!
Tags (1)
