Photographs
- Everything else
- Photographs
- « Previous
- 1
- 2
- Next »
Re: Photographs
18-07-2008 8:08 PM
There isn't, no - nor is there a set limit on size IIRC; PN just ask that it's used 'responsibly'.
Message 16 of 19
(290 Views)
Re: Photographs
19-07-2008 8:25 AM
[code=config.php]
<?php
$username="USERNAME";
$password="PASSWORD";
$database="DATABASE_NAME";
mysql_connect(localhost,$username,$password);
@mysql_select_db($database) or die( "Unable to select database");
[/code]
[code=index.php]
<?php
include_once ("/gallery/inc/config.php");
<!DOCTYPE html
PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html>
<head>
<title>Administration Panel :: Gallery</title>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<link rel="stylesheet" type="text/css" href="/gallery/styles/style.css?nocache />
$mode = $_GET['mode'];
if ($mode == "addimage"){
$countResult = mysql_query("SELECT * FROM gallery");
$imgID = mysql_num_rows($countResult);
$imgID = $imgID + 1;
$imgName = $_POST['imgName'];
$imgDesc = $_POST['imgDesc'];
$uploadLocation = "/gallery/photos/";
if ($imgName == "" && $imgDesc == "") {
<form name="imgUpload" method="POST" action="<?php echo $_SERVER['PHP_SELF']; ?>" enctype="multipart/form-data">
<table width="60" border="0" cellspacing="0" cellpadding="0">
<tr class="style1">
<td nowrap><div align="right">Image ID:</div></td>
<td><?php echo $imgID; ?></td>
</tr>
<tr class="style1">
<td nowrap><div align="right">Description: </div></td>
<td><textarea name="imgDesc" cols="70" rows="20" class="style1" id="imgDesc"></textarea></td>
</tr>
<tr class="style1">
<td nowrap><div align="right">Image Filename: </div></td>
<td><input type="file" name="imgName"><br /></td>
</tr>
<tr>
<td> </td>
<td><input type="hidden" name="MAX_FILE_SIZE" value="25000"><input name="Submit" type="submit" value="Submit"></td>
</tr>
</table>
</form>
</body>
</html>
} else {
if (is_uploaded_file($_FILES['imgName']['tmp_name'])){
$newImgLoc = $uploadLocation . $_FILES['imgName']['name'];
if (!copy($imgName, $newImgLoc)){
print "Error Uploading File.";
exit();
} else {
$query = mysql_query("INSERT INTO gallery (imgID,imgName,imgDesc) VALUES ('$imgID','$imgName','$imgDesc')");
if(!$query) {
$err=mysql_error();
echo "There was an error reported. The error was:" . $err;
exit();
} else {
echo "<p class='style1'>Photo has been uploaded. <a href='index.php'>Go back to Admin Panel.</a></p>";
exit;
} else {
<p class="style1">Please choose an option..</p>
<p class="style1"><a href="index.php?mode=addimage">1) Upload Photo</a></p>
<br />
<br />
<span class="style1">Current Date/Time : <?php echo date("H:i d-M-Y"); ?></span><br />
[/code]
Untested (as I don't have time to). Should let you upload an image to webspace, and allows for additions to the code (delete image, view images, edit image description, etc). I've not included the client-facing code to display the images and descriptions, again as I don't have time (but I'm sure somebody on here can help out with that).
<?php
[/code]
[code=index.php]
<?php
<!DOCTYPE html
<html>
<head>
<tr class="style1">
</tr>
<tr class="style1">
</tr>
<tr class="style1">
</tr>
<tr>
<td> </td>
</tr>
</table>
</form>
</body>
</html>
} else {
exit();
} else {
if(!$query) {
$err=mysql_error();
exit();
} else {
exit;
} else {
<br />
<br />
[/code]
Message 17 of 19
(290 Views)
Re: Photographs
19-07-2008 11:09 PM
Well ...
Not bad seing as that's all off the top of the head as an idea
I'd have gone for a Select & Case approach,
with each page action in a separate file in a sub-directory.
For the other parts there would have to be some protection against:
If you are going about it manually and requre help,
we can provide Snippets and/or Source.
Jim,
- Code Upload/Inclusion - There is no filtering what-so-ever on File Extensions &/ Data types, you'll hav to use an Image library (such as the PHP GD extension) to determin weather the file is an Image to allow the file to be stored or subsequently removed.
- SQL Injection - Database driven things are notorious for haveing inadiqu
Jim,
Message 18 of 19
(290 Views)
Re: Photographs
21-07-2008 2:12 PM
Yea like I said, it was a pretty rough hash-up so that they could see roughly what they needs - wrote it up quickly before I headed out for a night out so didn't have any time to do extension checks (although to be fair it wouldn't have taken that much longer). The SQL injection is not so much of an issue, since the only person that will be uploading will be the webmaster, but I agree that it should be done for security-sake.
If this is the way you are looking to do things then I, as well as Prod_Man, will be happy to provide help for you to get your desired outcome.
Message 19 of 19
(290 Views)
- « Previous
- 1
- 2
- Next »
