Personal URL
- Everything else
- Personal URL
Personal URL
05-12-2019 4:46 PM
Hello
I noticed that there is a URL that points to the dynamic IP address allocated to my router. The form is
<Plusnet username>.plus.com
Will this be always the case?
I ask because I'm using a dynamic DNS provider but depending on which WiFi I'm on, the URL is resolved differently, which I don't understand. Perhaps they're caching values for too long or not observing the TTL.
To make life simpler, I'd like to switch to using the plusnet URL for my dynamic IP address.
Praful
Praful
Message 1 of 3
(356 Views)
2 REPLIES 2
Re: Personal URL
05-12-2019 9:53 PM
Moderators Note
This topic has been moved from Fibre to Everything Else
Message 2 of 3
(311 Views)
Re: Personal URL
06-12-2019 4:03 PM
Hi @praful and welcome to the Community Forums.
I've looking into your current IP settings and although I can't confirm the specifics via this support channel I've updated a ticket on your account which can be seen here.
By all means if you can reply on the ticket which course of action you'd like us to take and then drop us a message on here after doing so as we'll get this picked up and actioned for you.
Message 3 of 3
(254 Views)
