Perl Module Date::Calc missing
- Everything else
- Perl Module Date::Calc missing
17-03-2010 6:41 PM
Date::Calc was present before this weekends fiasco and is now missing. I know this because my scripts have a dependency on it.
This link lists all modules:
http://ccgi.unclezen.plus.com/cgi-bin/dev/test/list-modules.pl
If possible could you supply a list of new modules - i.e. modules that were not present before and are present now
thanks
thanks
Message 1 of 3
(979 Views)
2 REPLIES 2
Re: Perl Module Date::Calc missing
18-03-2010 11:48 AM
It should be there now. The old platform had pretty much every library under the sun installed, which is something we want to avoid with the new one as it makes it very difficult to keep up to date. Going forward, unless there is a debian package available in the standard repositories, or there is a very compelling reason for a library to be installed, we won't be installing it on the platform.
Message 2 of 3
(409 Views)
18-03-2010 1:14 PM
Many Thanks, I can confirm that my sites appaear to be working as expected now.
Message 3 of 3
(409 Views)
- Everything else
