Paying for domain, can't work out how to manage it
- Everything else
- Paying for domain, can't work out how to manage it
24-07-2013 11:20 PM
Re: Paying for domain, can't work out how to manage it
25-07-2013 12:19 AM
Using FileZilla I get the following dialogue.
Status: Resolving address of homepages.force9.net <<<< force9 in my case because I'm a force9 customer
Status: Connecting to 212.159.8.90:21...
Status: Connection established, waiting for welcome message...
Response: 220-PLEASE NOTE: If you have a non-subscription account you
Response: 220-will only be able to login to this ftp server if you are
Response: 220-dialled into our network.
Response: 220-
Response: 220-A Maximum of 4 concurrent connections are allowed to this
Response: 220-server, each session is limited to 256KB/s downloads.
Response: 220-
Response: 220 Force9 FTP Server #1 ready
Command: USER xxxxxxxx <<<< xxxxxxxx is my username
Response: 331 Password required for xxxxxxxx
Command: PASS ********
Response: 230 User xxxxxxxx logged in
(various capability commands)
Status: Connected
(... and the session continues).
Once logged in you upload your website HTML files to the /htdocs folder. They should then be viewable in your favourite browser at www.<your username>.plus.com/index.htm or www.yourdomain.co.uk assuming DNS points it to homepages.
25-07-2013 12:42 AM
25-07-2013 2:08 AM
25-07-2013 8:02 AM
Quote from: siouxsie It's FileZilla that I'm using. Looks to me I'm not getting my password right, is the login the same as I use to log in on the Plusnet website?
No, the FTP server is showing that it can't establish a secure connection using TLS or SSL. It's not getting as far as logging on with your username or password.
Solution - Set Encryption to 'Use plain FTP'
25-07-2013 6:46 PM
I got the domain very recently, and besides my home broadband connection it's all I've paid for, does it maybe take some time before I can get on or is there more I need to buy?
25-07-2013 6:54 PM
Could this be the reason?
25-07-2013 7:05 PM
If you get an error 530 this means that your login data isn't accepted by the server. Double check your login details and/or as pwatson said check you have web space.
27-07-2013 3:50 PM
27-07-2013 4:12 PM
You could have gone to a third party and bought a combined package.
I don't know why Plusnet still sell domains if they no longer offer web space.
19-08-2013 7:39 PM
- Everything else
