PHP question - naive or oddball...
- Everything else
- PHP question - naive or oddball...
17-05-2012 11:39 AM
I feel I should know the answer to my own question, but...
I have a PHP page which:
- near the top generates an HTML page (using both PHP and some straight embedded HTML)
and
- near the bottom does some time-consuming (I/O and CPU time) operations entirely within PHP
Question: does the PHP interpreter wait until PHP operations have concluded on the page (i.e. in my case all the 'bottom bit' has finished) before outputting the HTML or is the HTML output as it is encountered during interpretation?
and
Zen from May 17. PN Business account from 2004 - 2017
Message 1 of 4
(1,341 Views)
3 REPLIES 3
Re: PHP question - naive or oddball...
17-05-2012 2:06 PM
Don't know the definitive answer but I suspect it could be a bit of both depending on the amount of output.
I think output is compressed (gzip, deflate) and sent in chunks so nothing appears until a chunk has been created and sent. If there is only a small amount of output (one chunk) nothing will be sent/appear until "end of file" is recognised.
I doubt that PHP interprets sending the closing </html> tag for the page as a hint to send "end of file" to the browser.
David
Message 2 of 4
(201 Views)
20-05-2012 9:08 PM
Not naive. Probably oddball.
Assuming we're talking Apache: yes, mod-deflate will add another layer of buffering (default 8k), which could leave your browser waiting for the script, but even if you turn that off (e.g. using
in .htaccess), Apache still won't close the connection till after the script has run. Some browsers will show you the html if you flush it to them, others will wait for the connection to close. To close the connection part way through a script, you need to buffer the output using PHP and flush it along with close headers (and a no-encoding header so that Apache doesn't buffer it). E.g., something like:
Gabe
SetEnvIfNoCase Request_URI \.php$ no-gzip dont-vary
<?php
ignore_user_abort(true);
ob_start();
echo '<!DOCTYPE html>
<html>
<head>
<title>A Page</title>
</head>
<body>
Some content.
</body>
</html>';
header('Content-Encoding: none');
header('Connection: close');
header('Content-Length: '.ob_get_length());
ob_end_flush();
sleep(10);
file_put_contents('log.txt','Log something.');
Gabe
Message 3 of 4
(201 Views)
24-05-2012 2:26 PM
Many thanks Spraxyt and Gabe.
I will experiment with ob_end_flush(). But since my problem is indicative of rubbishly structured code, I will probably end up splitting the 'page outputting' and machine intensive parts and using AJAX for the both (with the first passing data - or at least a 'completion semaphore' - to the second).
Message 4 of 4
(201 Views)
- Everything else
