PHP: Template script problem with preg_replace
- Everything else
- Re: PHP: Template script problem with preg_replace
19-12-2010 9:29 PM
Hi
I have written my own function to parse my template and replace tokens with their appropriate value.
Here is an example:
Now in my function I am using str_replace() to replace the tokens with their appropriate value - if it exists. This is how I pass do it in php:
Normally this isn't a problem. If however I only replace the middle token I do have a problem:
At the end of the function I use preg_replace to blank out the unused tokens - for security (basically I hide any clue that admin links may be there).
This is what I'm using:
Doing this causes a problem - It looks at the entire line, recognises the beginnning and end on both the first and last key and blanks out the entire lot!
Just to recap:
Any ideas how I can deal with this?
Here is an example:
<html>
<__Some Content__> <__More Content__> <__Something Else__>
</html>
$Values['__Some Content__'] = 'Some';
$Values['__More Content__'] = 'More';
$Values['__Something Else__'] = 'Here';
$Template = preg_replace('/\<__(.*)__\>/', '', $Template);
Just to recap:
//It see's the first <__(and last)__> and treats it as one token and blanks out the entire thing
// including my content in the middle:
<__(Some Content__> More <__Something Else])__>
Message 1 of 3
(1,507 Views)
2 REPLIES 2
20-12-2010 12:18 AM
By default PCRE patterns are greedy, with the result you mentioned. The solution is to use a PCRE-specific modifier '?U' to make them non-greedy.
For your preg_replace this could be specified in two ways
[code=Method1]
$Template = preg_replace('/\<__(.*?U)__\>/', '', $Template);[/code]
[code=Method 2]
$Template = preg_replace('/(?U)\<__(.*)__\>/', '', $Template);[/code]
In your case both methods should give the same result since there is only one quantifier. However Method 1 applies the modifier only within the sub-pattern containing it; Method 2 applies the modifier at top-level so that it applies to all quantifiers throughout the rest of the pattern.
David
[code=Method1]
[code=Method 2]
David
David
Message 2 of 3
(427 Views)
20-12-2010 10:41 AM
I'll give that a try
Message 3 of 3
(427 Views)
- Everything else
