[PAYH] trial, Plesk, AWStats, Unresolved IP address
Ponds
Hello. AWStats reports all IP Addresses as unresolved - even 212.56.83.232, which nslookup tells me is plesk-host03.plus.net.  The AWStats documentation on sourceforge.net says
"FAQ-COM200 : HOW REVERSE DNS LOOKUP WORKS, UNRESOLVED IP ADDRESSES
PROBLEM:
The reported page AWStats shows me has no hostnames, only IP addresses, countries reported are all "unknown".
SOLUTION:
When AWStats find an IP address in your log file, it tries a reverse DNS lookup to find the hostname and domain if the DNSLookup parameter, in your AWStats config file, is DNSLookup=1 (Default value). So, first, check if you have the good value. The DNSLookup=0 must be used only if your log file contains already resolved IP address."
Does anyone know if/how  I can get to the config file to check this?
