[PAYH] Why only 125mb space and 768mb monthly usage?
- Everything else
- [PAYH] Why only 125mb space and 768mb monthly usag...
16-12-2008 11:34 AM
Is there something I have done that has caused me to get only half my allowance?
I had a previous PAYH account whilst i did some testing and i wonder if that's where my other half is.
If so, how do i wipe the other one clear now that i don't need it?
In the plesk control panel for the old one, I've deleted the files and database, removed the hosting and generally cleared everything off.
Message 1 of 4
(1,029 Views)
3 REPLIES 3
Re: [PAYH] Why only 125mb space and 768mb monthly usage?
16-12-2008 11:40 AM
By default only half the space gets allocated to your domain - you need to go in to setup on the domain and allocate the rest.
Message 2 of 4
(134 Views)
16-12-2008 11:40 AM
Hi
Once logged in to your Plesk control panel, click home, then on to the domain, then limits.
From here you will be able to set the limits you want to have for that domain.
By default when the domain is added it only sets the limit for that domain to half what is available.
Message 3 of 4
(134 Views)
16-12-2008 2:14 PM
Thanks guys, I'd found it and was going to say so but you beat me to it.
Thanks anyway
Thanks anyway
Message 4 of 4
(134 Views)
- Everything else
