[PAYH] - Visitor Counter
Midnight_Caller
Hi All
I need a Free Visitor Counter with a control panel, so that I can create New Counters for my sites, I hav a number of sites!
I do not want a Free Jelly Counter or such like!
I want the Visitor Counter to be hosted on my PAYH account.
This is because the Front Page Servers are shutting Down, on 15th October 2009.
All that I have on the Front Page Servers is my Counters so I am asking for your help to solv this problem.
9 REPLIES 9
mal0z
Re: [PAYH] - Visitor Counter
I would recommend Google Analytics
or if you want one of the old style counters - I have used http://www.sitemeter.com/
Midnight_Caller
No I do not want: Google Analytics or Free Jelly Counter or such like!
john
How this
a simple php script with a text file to record the count.
To include in your website
<img src="counter.php" />
Demo
Download
Edit
Demo and Download link remove as they no longer work
You will need to make counter.txt writable (chmod 666)
Midnight_Caller
That will not work on my other sites that are hosted on F9 & PlusNet Home pages servers.  I need a way to generate the Code that gos on my sites from the control panel.
jelv
Fixes: 10
With a simple (and obvious) modification it will!
<img title="Visit counter" src="http://ccgi.username.plus.com/counter.php">
or for a perl script
<img title="Visit counter" src="http://ccgi.username.plus.com/cgi-bin/counter.pl">
You can obviously point those wherever you like!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Midnight_Caller
jelv, so how do I do that on PAYH?  I don't use the CGI platform, plus the CGI Servers are getting swapped out Nex week.
[Edit]
The out put is a image, I need the out put to be text, plus it is a Hit Counter.  So it is no good for me! - Next  Sad
mal0z
Not sure what you want then Gary - can you point to a site that has something you want ?
and many people regard visible  hit counters as rather noddy anyway - you don't see one on professional website such as this PN one  Smiley
PN use Google Analytics
<script src="http://www.google-analytics.com/urchin.js" type="text/javascript"></script>
<script type="text/javascript">
Midnight_Caller
Watt I want is a Text Visitor Counter with a control panel, so that I can have the code generated for my sites.  I want the Visitor Counter generator hosted on my PAYH Account.  It needs to be a Text Visitor Counter to comply with the Disability Discrimination Act.
Yes Technically I can have a image with a ALT tag on it!  But I don't want to use images for the counters.
bobpullen
Fixes: 316
Quote from: Midnight
How about something like this that you can see in action here (hosted on the PAYH servers).
