[PAYH] Unknown MySQL server host
- Everything else
- [PAYH] Unknown MySQL server host
07-04-2009 12:21 PM
I am unable to access mySQL database - I am not sure if I am using the correct host name (username_db).
Could some one clarify the correst hostname on PAYH
many thanks
many thanks
Message 1 of 5
(1,795 Views)
4 REPLIES 4
Re: [PAYH] Unknown MySQL server host
07-04-2009 12:45 PM
Are you trying to access the mySQL database from a program running on PAYH or from a program running on a local PC?
Message 2 of 5
(586 Views)
07-04-2009 1:17 PM
it is from the PAYH server
Message 3 of 5
(586 Views)
07-04-2009 3:43 PM
If you go to databases under the domain you are using in Plesk it gives the server name against the database. It will be something like plesk-db01.plus.net:3306 (I don't know if there are multiple servers).
Message 4 of 5
(586 Views)
07-04-2009 4:03 PM
plesk-db01.plus.net seems to work.
Many thanks for your prompt reply
Message 5 of 5
(586 Views)
- Everything else
