[PAYH] Graphics tookits - A Question !
- Everything else
- [PAYH] Graphics tookits - A Question !
20-01-2009 9:40 AM
I have Gd configured and working but would have also expected to see either or both ImageMagick and NetPBM.
My installation is in need of something to render .png images and I'm struggling at the moment.
Thanks,
Paul
Re: [PAYH] Graphics tookits
20-01-2009 10:12 AM
Perhaps some kind person from Plusnet could install them?
Gabe
Re: [PAYH] Graphics tookits - A Question !
22-01-2009 11:36 AM
22-01-2009 1:48 PM
On the Gallery 2 website this indicates that it will work with GD
Can you please let us know what issues you are experiencing?
Also do you know what libraries you are requiring if we were to install Imagemagick and whether you are using php/perl/cgi with this.
22-01-2009 2:06 PM
The issue in Gallery is with Watermarking images (with a semi-transparent PNG image), GD is not good at this task whereas ImageMagick is recommended.
Regarding installation there is detailed info here http://codex.gallery2.org/Installing_an_Image_Processing_Library
Thanks,
Paul
23-01-2009 10:01 AM
We have now installed Imagemagick
http://regster.co.uk/php.php
imagick
ImageMagick support enabled
Magick Backend ImageMagick
ImageMagick version 6.2.4
PHP imagick version 0.9.11
MaxRGB 65535
Supported image formats 8BIM
Font Family - Name AvantGarde - AvantGarde-Book
23-01-2009 11:42 AM
For Gallery users, the path is the default /usr/bin/ and I've just had it confirmed that the security warning thrown up by Gallery when you Test Settings has been fixed for this version.
Gabe
23-01-2009 11:58 AM
There is a known issue with the version that has been installed
ImageMagick 6.2.4 - This version may fail to watermark images (no errors reported, watermarks simply don't appear). Workaround: upgrade ImageMagick or use a different toolkit module (like NetPBM).
Above extracted from http://codex.gallery2.org/Gallery2:Known_Issues
Any chance of an upgrade?
Paul
23-01-2009 8:14 PM
Second the previous request, with thanks for the help so far.
Gabe
26-01-2009 12:53 PM
We have installed the latest stable release that is available for Debian.
Debian who are hoping to release a later version of their operating system in the future, may resolve this by adding a more up todate version on the their stable release. Until that happens unfortunately we are unable to install any later versions of this software.
26-01-2009 1:34 PM
Is it possible then to enable NetPBM to use as an alternative to ImageMagick please?
Paul
- Everything else
