[PAYH] FTPS, SFTP?
- Everything else
- Re: [PAYH] FTPS, SFTP?
[PAYH] FTPS, SFTP?
29-10-2008 10:43 AM
Sorry if this is a dumb question :-[, but is there an ftps or sftp option on payh?
Gabe
Gabe
Message 1 of 4
(1,212 Views)
3 REPLIES 3
05-11-2008 5:08 PM
Hello there,
I am not a PAYH Customer, but I think I can direct you in the right way.
Try connecting with SSH (Using PuTTY) to the knwn hostname for your PAYH Hosting.
If you can get a Command Line my logic has it, you should* be able to use SFTP,
I am assuming you have an SFTP Client (I use WinSCP Personally).
*I have little knowledge of SFTP Servers, I've never had to configure one to know.
Hope that helps.
Jim,
Hope that helps.
Jim,
Message 2 of 4
(356 Views)
05-11-2008 5:15 PM
Neither work, just regular FTP.
Message 3 of 4
(356 Views)
07-11-2008 11:31 AM
Thanks Jim. (In my case it’s Fugu and Cyberduck.) Nothing doing on PAYH... yet? We’re stuck with plain-text-password FTP.
Thanks inspiration3. I was hoping I’d missed something. Some of us are going to have DPA compliance issues.
Gabe
Message 4 of 4
(356 Views)
- Everything else
