[PAYH] Connect to MySQL database with MySQL Administrator
- Everything else
- Re: [PAYH] Connect to MySQL database with MySQL Ad...
21-01-2009 9:04 PM
Is it possible to connect to my MySQL database directly with MySQL Administrator? The database is hosted on plesk-host04.plus.net, but I can't even ping this. Works OK by connecting to it from my account DB WebAdmin.
Tony
Tony
Message 1 of 4
(1,378 Views)
3 REPLIES 3
Re: [PAYH] Connect to MySQL database with MySQL Administrator
21-01-2009 11:04 PM
Message 2 of 4
(592 Views)
22-01-2009 6:48 PM
Thanks Chris,
I should have searched a bit harder!
I have an account with another webhost that seems perfectly able to manage the security issues with allowing access via ODBC. Never a problem there, so a move is tempting....
Tony
Tony
Message 3 of 4
(592 Views)
23-01-2009 1:24 PM
Yep, bit of a pain this isn't it?
MySQL Administrator is a good bit of kit, I used it a lot when I was on the ccgi server but now I can't
There was talk of allowing it should there be enough support for it as mentioned in the thread link provided by Chris
Message 4 of 4
(592 Views)
- Everything else
