[PAYH] Compression and Drupal
glyndev
A quick question. Does the PAYH server perform compression on served content as standard?.
I have installed Drupal and while configuring the settings I discovered that you are able to set it to compress cached pages but also gives this warning.
By default, Drupal compresses the pages it caches in order to save bandwidth and improve download times. This option should be disabled when using a webserver that performs compression.
I know that I have only asked with reference to Drupal but it may also be relevent to users of other packages
