[PAYH] Applications out of date
- Everything else
- [PAYH] Applications out of date
09-11-2008 7:12 PM
Mambo: Version available through Plesk 4.6.0, current Mambo release is 4.6.5
Any plans to bring these up to date?
Edit:
Mantis: Plesk 1.1.1, current 1.1.4
Coppermine: Plesk 1.3.3 (and gives a load of errors if you select it), current 1.4.19
Gallery: Plesk 2.2, current 2.3
xoops: Plesk 2.2, current 2.3.1
Re: [PAYH] Applications out of date
09-11-2008 7:28 PM
10-11-2008 8:40 AM
Some of their applications are hopeless out of date. And others the developers have given up years ago due to huge security holes, but they are still available.
But loss of control is the cost of having easy installation it seams
10-11-2008 11:14 AM
Ian
10-11-2008 11:33 AM
Quote Posted By: gaugau
Date: 2005-09-25 16:40
Summary: Maintenance release: cpg1.3.5 fixes XSS vulnerability
A XSS vulnerability has been found in the language selector. Everybody who runs coppermine (any version older than cpg1.3.5) will have to apply this security fix as soon as possible.
We have released a new package of the stable branch (cpg1.3.x) named "cpg1.3.5" that contains the above mentioned fix, plus some fixes of minor issues.
So three years on Plesk still hasn't updated with a security fix, never mind updating to the 1.4 branch!
See https://sourceforge.net/export/rss2_projnews.php?group_id=89658&rss_fulltext=1 for a list of all the releases Plesk have ignored. When it is that far out of date, surely it would be better to pull it?
Edit: Or at least highlight that the user should consider downloading the current version themselves rather than use the bundled version?
10-11-2008 11:38 AM
The version we offer in the application vault is Coppermine v1.4.16
We updated the applications last week
10-11-2008 12:01 PM
10-11-2008 1:04 PM
10-11-2008 1:31 PM
10-11-2008 1:48 PM
M
10-11-2008 2:09 PM
10-11-2008 2:14 PM
Quote from: jelv Just gone back to check and yes that version is at the bottom of the page. So why is 1.3.3 still shown at the top of the page?
Numerical order. Is this important? I don't think there are many (if any) other apps with multiple versions in the vault, so you won't be trawling through a large list of builds.
10-11-2008 2:18 PM
Unless a build is very new and/or has issues running on PAYH, I can't see any reason to offer outdated versions. You should be encouraging people to keep up to date.
10-11-2008 2:32 PM
Be aware that application vault packages will pretty much continually be slightly behind the latest release. The reason for this is that each software release has to be fully tested (centrally) then converted into a compatible Plesk based package which can be included on (all) servers as an auto-update via appvault. The aim is a convenient installation and yes after this you would be expected to keep yourself up-to-date with the latest security patches.
[Moderator's note by Jonathan (chillypenguin): Full quote of preceding post removed, as per Forum Rules :mand: ]
19-11-2008 6:56 PM
- Everything else
