Open Port 80 on Zero 2704n Router
- Everything else
- Re: Open Port 80 on Zero 2704n Router
01-04-2015 12:41 PM
Hi all,
I have done a search and cannot see a deffinate answer. Basically I have just joined Plusnet and got the new router, I am trying to setup Port Forwarding for my CCTV camera's so I can access them from my works PC.
On my old router with sky it wasn't so bad but with this one I'm at a complete loss. Is there a 'idiots' guide on how to open these or indeed add one, I have turned the firewall settings off.
Thanks and hope this makes sense.
Message 1 of 4
(1,539 Views)
3 REPLIES 3
01-04-2015 1:22 PM
Should be fairly simple and you shouldn't need to disable the firewall.
I suspect port 80 is used for one of the pre-configured applications (web server?). You'd need to create a port forwarding/application sharing rule to point this to the local IP of your CCTV cameras.
Message 2 of 4
(768 Views)
01-04-2015 1:35 PM
I vaguely remember if you tried to create a Port 80 forward on this router it wouldn't let you as there is already one configured in the presets.
You need to choose this under the port forwarding section here :
http://www.plus.net/support/broadband/hardware/plusnet-2704n-advanced.shtml
Choose the http: option in the presets and you should be good to go.
Message 3 of 4
(768 Views)
01-04-2015 2:44 PM
Thanks guys ill give that a try when I get home
Message 4 of 4
(768 Views)
- Everything else
