Old website to close down
- Everything else
- Re: Old website to close down
22-04-2020 6:20 PM
I had a website (www. p******.plus.com) which I can hardly remember setting up. I used Mr Site (now taken over by TSOHost). I have since replaced that site with www.p******.co.uk. I didn't realise that the old site was still active until my wife stumbled across it. How can I delete that old site?
22-04-2020 6:23 PM
This topic has been moved from General Chat to Everything Else.
22-04-2020 8:33 PM
22-04-2020 11:10 PM
Thanks - I'll try to work out what this means. Think I have a friend who probably understands...
23-04-2020 1:24 PM
The only log in details I have seem to just get me into webmail etc
23-04-2020 2:42 PM - edited 23-04-2020 2:45 PM
So, just to confirm before I take action - You want the website completely deleting, yes? I will not be able to recover it should you change your mind afterwards.
Edit: you should deifnitely still be able to log into the website etc. The username may not be the same as your mailbox details though if you log into Webmail using something other than the default mailbox.
23-04-2020 4:04 PM
Absolutely agree to it being deleted completely:
www.pontart.plus.com is the one that needs to go...
Neil
25-10-2021 7:41 PM
The site has been queued for deletion Neil.
It should have disappeared by the end of the week.
Give me a nudge if not.
- Everything else
