Not pointing to hostopia server
- Everything else
- Not pointing to hostopia server
28-02-2014 3:00 PM
I have a hosted domain pointed to the CGI platform and have tried to change the DNS records to point to hostopia's servers but with no success. The files are uploading into the directory with no problem but when I try to access the uploaded files from another computer it's still the version that was transferred a few weeks ago - no edits are going live. I have used 91.136.8.9 as hostopia's servers - is this right? I changed the DNS records a week ago now.
Message 1 of 3
(827 Views)
2 REPLIES 2
Re: Not pointing to hostopia server
28-02-2014 3:23 PM
Yes that's the correct IP for the Hostopia servers.
If you run a
command in a command-prompt window on your PC does it return that IP address?
If you run a
nslookup your-ccgi-website-domain-name
David
Message 2 of 3
(331 Views)
28-02-2014 3:38 PM
Yes, it did, thanks. I've just realised I actually think it's the cached version on the work server that's getting me confused.
Message 3 of 3
(331 Views)
- Everything else
