Not Authorized to View This Page [CFN #0004] on ccgi
argonot
Re: Not Authorized to View This Page [CFN #0004] on ccgi
Site came alive again at 18:50. Thanks for sorting this out.
MatthewWheeler
Fixes: 480
Glad to hear that the issue is resolved for the majority of you.
@knowdice We can't see any issues remotely that would cause this. Have you tried resetting your account password here?
 Matthew Wheeler
knowdice
Hi Matthew, Yes have tried resetting password, and when phoning in to support get asked for 2 characters from password and these seem to be correct. Get this message when resetting password: You have successfully changed your password. There has been an error in updating your WebStats password, please try again later. Also have tried different browsers.
DaveDoc
Our site is now back and running - thanks.
RandallFlagg
Fixes: 75
Sorry to hear this, @knowdice
We can see the successful password resets being reflected on your account from our side, so it's odd that this isn't working for you.
Could you try deleting the cache/cookies of the browsers in question and then try setting your password to 'password' (without the punctuation) temporarily to see if that works (in case its a formatting issue).
If this doesn't work we'll likely need to raise this to our software team on your behalf.
Best wishes
Dave
duds
This is still an issue for me. Please PM is you need any specific details.
RandallFlagg
Fixes: 75
Hi @duds,
Sorry to hear that you're experiencing problems after the fix rollout.
Could you let us know how this is representing itself at your end? Do you see an error message as per the OP on this thread?
Dave
duds
This is resolved now... it looks like there were two issues. When the initial issue first occurred, I changed the PHP version setting in the portal. Just now I edited the php change out of the .htaccess file in the public folder. Now my sites are restored.
RandallFlagg
Fixes: 75
Glad to hear this, @duds
Let us know if there's anything else you need.
Best wishes
Dave
Kiwi2
Dave,
Thanks to you and the team for helping sort this out over the last few days.
Kiwi
knowdice
Dave,
That worked, wasn't the cache.
FYI you can't use "password" so used "password2".
And have gone to a completely new secure password  Wink
Many thanks for your help.
