Nord VPN
markatlogic
Nord VPN
Just started Using Nord VPN, would I be better using a static IP from Plusnet?
2 REPLIES 2
Mav
Fixes: 518
Re: Nord VPN
Moderator's note(s):
Thread moved from Broadband to Everything Else.
Forum Moderator and Customer
corringham
Seasoned Champion
Fixes: 23
Re: Nord VPN
Do you mean using a static IP instead of using Nord VPN?
If you want an externally visible address so that you can access your devices from the internet, then a static IP will do that. There is a one-off charge from Plusnet, so it can be cheaper than a paid for VPN.
If you use a VPN to hide your real address or filter out malware, then of course a static IP won't help with that.
